Setting up xtables-addons-dkms (3.13-1) ...
Removing old xtables-addons-3.13 DKMS files...
Deleting module version: 3.13
completely from the DKMS tree.
Done.
Loading new xtables-addons-3.13 DKMS files...
Building for 5.10.0-16-amd64
Building initial module for 5.10.0-16-amd64
Error! Build of xt_ACCOUNT.ko failed for: 5.10.0-16-amd64 (x86_64)
Make sure the name of the generated module is correct and at the root of the
build directory, or consult make.log in the build directory
/var/lib/dkms/xtables-addons/3.13/build/ for more information.
dpkg: error processing package xtables-addons-dkms (--configure):
installed xtables-addons-dkms package post-installation script subprocess returned error exit status 7
Errors were encountered while processing:
xtables-addons-dkms
Reading package lists...
Building dependency tree...
Reading state information...
xtables-addons-dkms is already the newest version (3.13-1).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
1 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Done.
xtables-addons-dkms
