Problem podłączeniem smartfonu do laptopa
korbielow
Post autor: korbielow »
Po podlaczeniu telefonu pod laptop dostaje taki komunikat:
Chciałem coś zgrać i niestety mam problem.
Re: Problem podłączeniem smartfonu do laptopa
Coś więcej może powiedzieć wynik z dmesg.
korbielow
wynik z dmesg
[    3.459469] uvcvideo 1-1.4:1.0: Entity type for entity Extension 3 was not initialized!
[    3.459471] uvcvideo 1-1.4:1.0: Entity type for entity Processing 2 was not initialized!
[    3.459473] uvcvideo 1-1.4:1.0: Entity type for entity Camera 1 was not initialized!
[    3.463064] input: Laptop_Integrated_Webcam_3M: In as /devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.4/1-1.4:1.0/input/input10
[    3.463197] usbcore: registered new interface driver uvcvideo
[    3.463198] USB Video Class driver (1.1.1)
[    3.497107] Bluetooth: Core ver 2.22
[    3.497127] NET: Registered protocol family 31
[    3.497128] Bluetooth: HCI device and connection manager initialized
[    3.497134] Bluetooth: HCI socket layer initialized
[    3.497137] Bluetooth: L2CAP socket layer initialized
[    3.497144] Bluetooth: SCO socket layer initialized
[    3.523116] dcdbas dcdbas: Dell Systems Management Base Driver (version 5.6.0-3.2)
[    3.525427] usbcore: registered new interface driver btusb
[    3.535971] kvm: VM_EXIT_LOAD_IA32_PERF_GLOBAL_CTRL does not work properly. Using workaround
[    3.541632] dell-smbios A80593CE-A997-11DA-B012-B622A1EF5492: WMI SMBIOS userspace interface not supported(0), try upgrading to a newer BIOS
[    3.579417] input: Dell WMI hotkeys as /devices/platform/PNP0C14:00/wmi_bus/wmi_bus-PNP0C14:00/9DBB5994-A997-11DA-B012-B622A1EF5492/input/input11
[    3.616887] dell_laptop: Using i8042 filter function for receiving events
[    3.671562] Adding 8310780k swap on /dev/sda5.  Priority:-2 extents:1 across:8310780k SSFS
[    3.700711] Support for cores revisions 0x17 and 0x18 disabled by module param allhwsupport=0. Try b43.allhwsupport=1
[    3.700797] b43: probe of bcma0:1 failed with error -524
[    3.700830] Broadcom 43xx driver loaded [ Features: PNLS ]
[    3.728465] brcmsmac bcma0:1: mfg 4bf core 812 rev 24 class 0 irq 17
[    3.733444] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
[    3.736266] brcmsmac bcma0:1 wlp2s0b1: renamed from wlan0
[    3.933133] EXT4-fs (sdb5): mounted filesystem with ordered data mode. Opts: (null)
[    3.940044] pci 0000:00:00.0: Intel HD Graphics Chipset
[    3.940111] pci 0000:00:00.0: detected gtt size: 2097152K total, 262144K mappable
[    3.940596] pci 0000:00:00.0: detected 32768K stolen memory
[    3.940654] [drm] Replacing VGA console driver
[    3.941334] Console: switching to colour dummy device 80x25
[    3.944569] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    3.944571] [drm] Driver supports precise vblank timestamp query.
[    3.946387] i915 0000:00:02.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=io+mem:owns=io+mem
[    3.970253] [drm] RC6 disabled, disabling runtime PM support
[    3.972814] [drm] Initialized i915 1.6.0 20171222 for 0000:00:02.0 on minor 0
[    3.973192] ACPI: Video Device [VID1] (multi-head: yes  rom: no  post: no)
[    3.982171] acpi device:3f: registered as cooling_device5
[    3.982640] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:01/input/input12
[    4.000008] snd_hda_intel 0000:00:1b.0: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
[    4.001433] fbcon: inteldrmfb (fb0) is primary device
[    4.014969] dell_wmi: Unknown key with type 0x0011 and code 0xffd0 pressed
[    4.017028] audit: type=1400 audit(1538042425.513:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/sbin/cups-browsed" pid=468 comm="apparmor_parser"
[    4.017632] audit: type=1400 audit(1538042425.513:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/sbin/libvirtd" pid=466 comm="apparmor_parser"
[    4.017637] audit: type=1400 audit(1538042425.513:4): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/sbin/libvirtd//qemu_bridge_helper" pid=466 comm="apparmor_parser"
[    4.019468] snd_hda_codec_idt hdaudioC0D0: autoconfig for 92HD81B1C5: line_outs=1 (0xe/0x0/0x0/0x0/0x0) type:line
[    4.019470] snd_hda_codec_idt hdaudioC0D0:    speaker_outs=1 (0xd/0x0/0x0/0x0/0x0)
[    4.019472] snd_hda_codec_idt hdaudioC0D0:    hp_outs=1 (0xb/0x0/0x0/0x0/0x0)
[    4.019473] snd_hda_codec_idt hdaudioC0D0:    mono: mono_out=0x0
[    4.019474] snd_hda_codec_idt hdaudioC0D0:    inputs:
[    4.019476] snd_hda_codec_idt hdaudioC0D0:      Dock Mic=0xf
[    4.019477] snd_hda_codec_idt hdaudioC0D0:      Internal Mic=0x11
[    4.019479] snd_hda_codec_idt hdaudioC0D0:      Mic=0xa
[    4.020499] audit: type=1400 audit(1538042425.517:5): apparmor="STATUS" operation="profile_load" profile="unconfined" name="libreoffice-xpdfimport" pid=473 comm="apparmor_parser"
[    4.020921] audit: type=1400 audit(1538042425.517:6): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/cups/backend/cups-pdf" pid=469 comm="apparmor_parser"
[    4.020924] audit: type=1400 audit(1538042425.517:7): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/sbin/cupsd" pid=469 comm="apparmor_parser"
[    4.020927] audit: type=1400 audit(1538042425.517:8): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/sbin/cupsd//third_party" pid=469 comm="apparmor_parser"
[    4.022209] audit: type=1400 audit(1538042425.517:9): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/bin/man" pid=472 comm="apparmor_parser"
[    4.022213] audit: type=1400 audit(1538042425.517:10): apparmor="STATUS" operation="profile_load" profile="unconfined" name="man_filter" pid=472 comm="apparmor_parser"
[    4.066798] input: HDA Digital PCBeep as /devices/pci0000:00/0000:00:1b.0/sound/card0/input13
[    4.071089] input: HDA Intel MID Dock Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input14
[    4.071185] input: HDA Intel MID Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input15
[    4.071275] input: HDA Intel MID Dock Line Out as /devices/pci0000:00/0000:00:1b.0/sound/card0/input16
[    4.071385] input: HDA Intel MID Headphone as /devices/pci0000:00/0000:00:1b.0/sound/card0/input17
[    4.071474] input: HDA Intel MID HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1b.0/sound/card0/input18
[    4.071553] input: HDA Intel MID HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:1b.0/sound/card0/input19
[    4.350703] random: crng init done
[    4.350705] random: 7 urandom warning(s) missed due to ratelimiting
[    4.498049] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[    4.498050] Bluetooth: BNEP filters: protocol multicast
[    4.498057] Bluetooth: BNEP socket layer initialized
[    5.570619] Console: switching to colour frame buffer device 180x56
[    5.580748] dell_wmi: Unknown key with type 0x0011 and code 0xffd1 pressed
[    5.601534] i915 0000:00:02.0: fb0: inteldrmfb frame buffer device
[    5.701775] IPv6: ADDRCONF(NETDEV_UP): eno1: link is not ready
[    5.928365] IPv6: ADDRCONF(NETDEV_UP): eno1: link is not ready
[    5.936566] IPv6: ADDRCONF(NETDEV_UP): wlp2s0b1: link is not ready
[    5.938020] brcmsmac bcma0:1: firmware: direct-loading firmware brcm/bcm43xx-0.fw
[    5.938354] brcmsmac bcma0:1: firmware: direct-loading firmware brcm/bcm43xx_hdr-0.fw
[    6.006751] brcmsmac bcma0:1: brcms_ops_bss_info_changed: qos enabled: false (implement)
[    6.006767] brcmsmac bcma0:1: brcms_ops_config: change power-save mode: false (implement)
[    6.006994] IPv6: ADDRCONF(NETDEV_UP): wlp2s0b1: link is not ready
[    6.088635] brcmsmac bcma0:1: brcms_ops_bss_info_changed: qos enabled: false (implement)
[    6.088653] brcmsmac bcma0:1: brcms_ops_config: change power-save mode: false (implement)
[    6.088839] IPv6: ADDRCONF(NETDEV_UP): wlp2s0b1: link is not ready
[    6.184709] IPv6: ADDRCONF(NETDEV_UP): wlp2s0b1: link is not ready
[    7.246218] fuse init (API version 7.26)
[    8.676246] intel ips 0000:00:1f.6: i915 driver attached, reenabling gpu turbo
[   11.986534] vmmon: loading out-of-tree module taints kernel.
[   11.988450] /dev/vmmon[780]: Module vmmon: registered with major=10 minor=165
[   11.988454] /dev/vmmon[780]: Using tsc_khz as TSC frequency: 2659983
[   11.988456] /dev/vmmon[780]: Module vmmon: initialized
[   12.009651] Guest personality initialized and is inactive
[   12.009974] VMCI host device registered (name=vmci, major=10, minor=56)
[   12.009975] Initialized host personality
[   12.043116] NET: Registered protocol family 40
[   12.889894] /dev/vmnet: open called by PID 1136 (vmnet-netifup)
[   12.889903] /dev/vmnet: hub 1 does not exist, allocating memory.
[   12.889927] /dev/vmnet: port on hub 1 successfully opened
[   12.898591] brcmsmac bcma0:1: brcms_ops_bss_info_changed: qos enabled: false (implement)
[   12.898606] brcmsmac bcma0:1: brcms_ops_config: change power-save mode: false (implement)
[   12.898847] IPv6: ADDRCONF(NETDEV_UP): wlp2s0b1: link is not ready
[   12.916767] /dev/vmnet: open called by PID 1139 (vmnet-dhcpd)
[   12.916781] /dev/vmnet: port on hub 1 successfully opened
[   12.931457] /dev/vmnet: open called by PID 1163 (vmnet-natd)
[   12.931469] /dev/vmnet: hub 8 does not exist, allocating memory.
[   12.931496] /dev/vmnet: port on hub 8 successfully opened
[   12.937070] /dev/vmnet: open called by PID 1164 (vmnet-netifup)
[   12.937085] /dev/vmnet: port on hub 8 successfully opened
[   12.949753] /dev/vmnet: open called by PID 1168 (vmnet-dhcpd)
[   12.949768] /dev/vmnet: port on hub 8 successfully opened
[   13.816698] wlp2s0b1: authenticate with b8:62:1f:50:76:24
[   13.819302] wlp2s0b1: send auth to b8:62:1f:50:76:24 (try 1/3)
[   13.820817] wlp2s0b1: authenticated
[   13.823804] wlp2s0b1: associate with b8:62:1f:50:76:24 (try 1/3)
[   13.827373] wlp2s0b1: RX AssocResp from b8:62:1f:50:76:24 (capab=0x411 status=0 aid=4)
[   13.830934] brcmsmac bcma0:1: brcmsmac: brcms_ops_bss_info_changed: associated
[   13.830940] brcmsmac bcma0:1: brcms_ops_bss_info_changed: qos enabled: true (implement)
[   13.830950] wlp2s0b1: associated
[   13.834878] brcmsmac bcma0:1: wl0: brcms_c_d11hdrs_mac80211:  txop exceeded phylen 159/256 dur 1778/1504
[   13.841720] brcmsmac bcma0:1: wl0: brcms_c_d11hdrs_mac80211:  txop exceeded phylen 137/256 dur 1602/1504
[   13.854348] IPv6: ADDRCONF(NETDEV_CHANGE): wlp2s0b1: link becomes ready
[   13.856090] /dev/vmnet: open called by PID 1117 (vmnet-bridge)
[   13.856101] /dev/vmnet: hub 0 does not exist, allocating memory.
[   13.856124] /dev/vmnet: port on hub 0 successfully opened
[   13.856136] bridge-wlp2s0b1: device is wireless, enabling SMAC
[   13.856139] bridge-wlp2s0b1: up
[   13.856144] bridge-wlp2s0b1: attached
[   13.862175] brcmsmac bcma0:1: brcms_ops_bss_info_changed: arp filtering: 1 addresses (implement)
[   14.055990] userif-2: sent link down event.
[   14.055993] userif-2: sent link up event.
[   15.411745] Bluetooth: RFCOMM TTY layer initialized
[   15.411755] Bluetooth: RFCOMM socket layer initialized
[   15.411765] Bluetooth: RFCOMM ver 1.11
[  222.907045] wlp2s0b1: deauthenticated from b8:62:1f:50:76:24 (Reason: 7=CLASS3_FRAME_FROM_NONASSOC_STA)
[  222.910223] bridge-wlp2s0b1: disabling the bridge on dev down
[  222.910538] bridge-wlp2s0b1: down
[  222.910552] bridge-wlp2s0b1: detached
[  222.965978] brcmsmac bcma0:1: brcmsmac: brcms_ops_bss_info_changed: disassociated
[  222.965992] brcmsmac bcma0:1: brcms_ops_bss_info_changed: arp filtering: 1 addresses (implement)
[  222.965998] brcmsmac bcma0:1: brcms_ops_bss_info_changed: qos enabled: false (implement)
[  222.990588] wlp2s0b1: authenticate with b8:62:1f:50:76:24
[  222.990685] wlp2s0b1: send auth to b8:62:1f:50:76:24 (try 1/3)
[  222.992219] wlp2s0b1: authenticated
[  222.993880] wlp2s0b1: associate with b8:62:1f:50:76:24 (try 1/3)
[  222.997094] wlp2s0b1: RX AssocResp from b8:62:1f:50:76:24 (capab=0x411 status=0 aid=1)
[  222.997751] brcmsmac bcma0:1: brcmsmac: brcms_ops_bss_info_changed: associated
[  222.997761] brcmsmac bcma0:1: brcms_ops_bss_info_changed: arp filtering: 1 addresses (implement)
[  222.997767] brcmsmac bcma0:1: brcms_ops_bss_info_changed: qos enabled: true (implement)
[  222.997783] wlp2s0b1: associated
[  223.107222] userif-2: sent link down event.
[  223.107227] userif-2: sent link up event.
[  232.999575] wlp2s0b1: deauthenticating from b8:62:1f:50:76:24 by local choice (Reason: 3=DEAUTH_LEAVING)
[  233.000663] brcmsmac bcma0:1: brcmsmac: brcms_ops_bss_info_changed: disassociated
[  233.000675] brcmsmac bcma0:1: brcms_ops_bss_info_changed: arp filtering: 1 addresses (implement)
[  233.000681] brcmsmac bcma0:1: brcms_ops_bss_info_changed: qos enabled: false (implement)
[  233.982361] wlp2s0b1: authenticate with b8:62:1f:50:76:24
[  233.982426] wlp2s0b1: send auth to b8:62:1f:50:76:24 (try 1/3)
[  233.983939] wlp2s0b1: authenticated
[  233.985536] wlp2s0b1: associate with b8:62:1f:50:76:24 (try 1/3)
[  233.989114] wlp2s0b1: RX AssocResp from b8:62:1f:50:76:24 (capab=0x411 status=0 aid=2)
[  233.989771] brcmsmac bcma0:1: brcmsmac: brcms_ops_bss_info_changed: associated
[  233.989778] brcmsmac bcma0:1: brcms_ops_bss_info_changed: arp filtering: 1 addresses (implement)
[  233.989783] brcmsmac bcma0:1: brcms_ops_bss_info_changed: qos enabled: true (implement)
[  233.989796] wlp2s0b1: associated
[  234.443680] brcmsmac bcma0:1: wl0: brcms_c_d11hdrs_mac80211:  txop exceeded phylen 159/256 dur 1778/1504
[  234.460194] brcmsmac bcma0:1: wl0: brcms_c_d11hdrs_mac80211:  txop exceeded phylen 137/256 dur 1602/1504
[  234.461840] /dev/vmnet: open called by PID 1117 (vmnet-bridge)
[  234.461854] /dev/vmnet: hub 0 does not exist, allocating memory.
[  234.461947] /dev/vmnet: port on hub 0 successfully opened
[  234.461962] bridge-wlp2s0b1: device is wireless, enabling SMAC
[  234.461967] bridge-wlp2s0b1: up
[  234.461972] bridge-wlp2s0b1: attached
[  234.661438] userif-2: sent link down event.
[  234.661441] userif-2: sent link up event.
[  248.606256] brcmsmac bcma0:1: brcms_ops_bss_info_changed: arp filtering: 0 addresses (implement)
[  248.606692] wlp2s0b1: deauthenticating from b8:62:1f:50:76:24 by local choice (Reason: 3=DEAUTH_LEAVING)
[  248.608620] brcmsmac bcma0:1: brcmsmac: brcms_ops_bss_info_changed: disassociated
[  248.608629] brcmsmac bcma0:1: brcms_ops_bss_info_changed: qos enabled: false (implement)
[  248.631851] bridge-wlp2s0b1: disabling the bridge on dev down
[  248.631883] bridge-wlp2s0b1: down
[  248.632875] bridge-wlp2s0b1: detached
[  248.701678] brcmsmac bcma0:1: brcms_ops_bss_info_changed: qos enabled: false (implement)
[  248.701692] brcmsmac bcma0:1: brcms_ops_config: change power-save mode: false (implement)
[  248.702129] IPv6: ADDRCONF(NETDEV_UP): wlp2s0b1: link is not ready
[  248.807161] userif-2: sent link down event.
[  248.807163] userif-2: sent link up event.
[  256.113267] brcmsmac bcma0:1: brcms_ops_bss_info_changed: qos enabled: false (implement)
[  256.113285] brcmsmac bcma0:1: brcms_ops_config: change power-save mode: false (implement)
[  256.113568] IPv6: ADDRCONF(NETDEV_UP): wlp2s0b1: link is not ready
[  257.057919] wlp2s0b1: authenticate with b8:62:1f:50:76:24
[  257.057993] wlp2s0b1: send auth to b8:62:1f:50:76:24 (try 1/3)
[  257.059546] wlp2s0b1: authenticated
[  257.061041] wlp2s0b1: associate with b8:62:1f:50:76:24 (try 1/3)
[  257.064578] wlp2s0b1: RX AssocResp from b8:62:1f:50:76:24 (capab=0x411 status=0 aid=3)
[  257.065230] brcmsmac bcma0:1: brcmsmac: brcms_ops_bss_info_changed: associated
[  257.065237] brcmsmac bcma0:1: brcms_ops_bss_info_changed: qos enabled: true (implement)
[  257.065250] wlp2s0b1: associated
[  257.072150] brcmsmac bcma0:1: wl0: brcms_c_d11hdrs_mac80211:  txop exceeded phylen 159/256 dur 1778/1504
[  257.079352] brcmsmac bcma0:1: wl0: brcms_c_d11hdrs_mac80211:  txop exceeded phylen 137/256 dur 1602/1504
[  257.079765] IPv6: ADDRCONF(NETDEV_CHANGE): wlp2s0b1: link becomes ready
[  257.080330] /dev/vmnet: open called by PID 1117 (vmnet-bridge)
[  257.080340] /dev/vmnet: hub 0 does not exist, allocating memory.
[  257.080366] /dev/vmnet: port on hub 0 successfully opened
[  257.080375] bridge-wlp2s0b1: device is wireless, enabling SMAC
[  257.080378] bridge-wlp2s0b1: up
[  257.080382] bridge-wlp2s0b1: attached
[  257.089999] brcmsmac bcma0:1: brcms_ops_bss_info_changed: arp filtering: 1 addresses (implement)
[  257.280059] userif-2: sent link down event.
[  257.280063] userif-2: sent link up event.
[  549.211753] pci_bus 0000:0b: Allocating resources
[  549.211775] pci 0000:00:1e.0: bridge window [io  0x1000-0x0fff] to [bus 0b] add_size 1000
[  549.211782] pci 0000:00:1e.0: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 0b] add_size 200000 add_align 100000
[  549.211789] pci 0000:00:1e.0: bridge window [mem 0x00100000-0x000fffff] to [bus 0b] add_size 200000 add_align 100000
[  549.211811] pci 0000:00:1e.0: BAR 14: assigned [mem 0xf7200000-0xf73fffff]
[  549.211824] pci 0000:00:1e.0: BAR 15: assigned [mem 0xf7400000-0xf75fffff 64bit pref]
[  549.211834] pci 0000:00:1e.0: BAR 13: assigned [io  0x8000-0x8fff]
[  549.211845] pci 0000:00:1e.0: PCI bridge to [bus 0b]
[  549.211851] pci 0000:00:1e.0:   bridge window [io  0x8000-0x8fff]
[  549.211860] pci 0000:00:1e.0:   bridge window [mem 0xf7200000-0xf73fffff]
[  549.211868] pci 0000:00:1e.0:   bridge window [mem 0xf7400000-0xf75fffff 64bit pref]
[  549.216199] pci 0000:00:1e.0: PCI bridge to [bus 0b]
[  549.216207] pci 0000:00:1e.0:   bridge window [io  0x8000-0x8fff]
[  549.216215] pci 0000:00:1e.0:   bridge window [mem 0xf7200000-0xf73fffff]
[  549.216221] pci 0000:00:1e.0:   bridge window [mem 0xf7400000-0xf75fffff 64bit pref]
[  549.216270] pci 0000:00:1e.0: PCI bridge to [bus 0b]
[  549.216275] pci 0000:00:1e.0:   bridge window [io  0x8000-0x8fff]
[  549.216282] pci 0000:00:1e.0:   bridge window [mem 0xf7200000-0xf73fffff]
[  549.216304] pci 0000:00:1e.0:   bridge window [mem 0xf7400000-0xf75fffff 64bit pref]
[  549.216869] pci_bus 0000:01: Allocating resources
[  549.216889] pci_bus 0000:02: Allocating resources
[  549.216914] pci_bus 0000:03: Allocating resources
[  549.216988] pci_bus 0000:05: Allocating resources
[  549.217040] pci 0000:00:1e.0: PCI bridge to [bus 0b]
[  549.217044] pci 0000:00:1e.0:   bridge window [io  0x8000-0x8fff]
[  549.217051] pci 0000:00:1e.0:   bridge window [mem 0xf7200000-0xf73fffff]
[  549.217057] pci 0000:00:1e.0:   bridge window [mem 0xf7400000-0xf75fffff 64bit pref]
[  549.217114] pci 0000:00:1e.0: PCI bridge to [bus 0b]
[  549.217119] pci 0000:00:1e.0:   bridge window [io  0x8000-0x8fff]
[  549.217126] pci 0000:00:1e.0:   bridge window [mem 0xf7200000-0xf73fffff]
[  549.217130] pci 0000:00:1e.0:   bridge window [mem 0xf7400000-0xf75fffff 64bit pref]
[  549.217402] pci 0000:00:1e.0: PCI bridge to [bus 0b]
[  549.217407] pci 0000:00:1e.0:   bridge window [io  0x8000-0x8fff]
[  549.217414] pci 0000:00:1e.0:   bridge window [mem 0xf7200000-0xf73fffff]
[  549.217420] pci 0000:00:1e.0:   bridge window [mem 0xf7400000-0xf75fffff 64bit pref]
[  549.217497] pci 0000:00:1e.0: PCI bridge to [bus 0b]
[  549.217502] pci 0000:00:1e.0:   bridge window [io  0x8000-0x8fff]
[  549.217510] pci 0000:00:1e.0:   bridge window [mem 0xf7200000-0xf73fffff]
[  549.217515] pci 0000:00:1e.0:   bridge window [mem 0xf7400000-0xf75fffff 64bit pref]
[  549.217663] pci 0000:00:1e.0: PCI bridge to [bus 0b]
[  549.217668] pci 0000:00:1e.0:   bridge window [io  0x8000-0x8fff]
[  549.217674] pci 0000:00:1e.0:   bridge window [mem 0xf7200000-0xf73fffff]
[  549.217680] pci 0000:00:1e.0:   bridge window [mem 0xf7400000-0xf75fffff 64bit pref]
[  549.229674] dell_wmi: Unknown key with type 0x0011 and code 0xffd0 pressed
[  550.985604] brcmsmac bcma0:1: brcms_ops_bss_info_changed: arp filtering: 0 addresses (implement)
[  550.986028] wlp2s0b1: deauthenticating from b8:62:1f:50:76:24 by local choice (Reason: 3=DEAUTH_LEAVING)
[  550.989175] brcmsmac bcma0:1: brcmsmac: brcms_ops_bss_info_changed: disassociated
[  550.989184] brcmsmac bcma0:1: brcms_ops_bss_info_changed: qos enabled: false (implement)
[  551.008308] bridge-wlp2s0b1: disabling the bridge on dev down
[  551.008435] bridge-wlp2s0b1: down
[  551.011011] bridge-wlp2s0b1: detached
[  551.083096] brcmsmac bcma0:1: brcms_ops_bss_info_changed: qos enabled: false (implement)
[  551.083112] brcmsmac bcma0:1: brcms_ops_config: change power-save mode: false (implement)
[  551.083393] IPv6: ADDRCONF(NETDEV_UP): wlp2s0b1: link is not ready
[  551.130043] PM: suspend entry (deep)
[  551.130047] PM: Syncing filesystems ...
[  551.186351] userif-2: sent link down event.
[  551.186355] userif-2: sent link up event.
[  551.272642] done.
[  551.272983] (NULL device *): firmware: direct-loading firmware brcm/bcm43xx_hdr-0.fw
[  551.273029] (NULL device *): firmware: direct-loading firmware brcm/bcm43xx-0.fw
[  551.273042] Freezing user space processes ... (elapsed 0.002 seconds) done.
[  551.275293] OOM killer disabled.
[  551.275294] Freezing remaining freezable tasks ... (elapsed 0.001 seconds) done.
[  551.276363] Suspending console(s) (use no_console_suspend to debug)
[  551.296129] e1000e: EEE TX LPI TIMER: 00000000
[  551.296282] sd 0:0:0:0: [sda] Synchronizing SCSI cache
[  551.296302] sd 1:0:0:0: [sdb] Synchronizing SCSI cache
[  551.296748] sd 0:0:0:0: [sda] Stopping disk
[  551.309649] sd 1:0:0:0: [sdb] Stopping disk
[  552.420806] ACPI: EC: interrupt blocked
[  552.440584] ACPI: Preparing to enter system sleep state S3
[  552.443367] ACPI: EC: event blocked
[  552.443368] ACPI: EC: EC stopped
[  552.443369] PM: Saving platform NVS memory
[  552.443389] Disabling non-boot CPUs ...
[  552.456715] IRQ 25: no longer affine to CPU1
[  552.457735] smpboot: CPU 1 is now offline
[  552.480701] IRQ 26: no longer affine to CPU2
[  552.481913] smpboot: CPU 2 is now offline
[  552.504644] IRQ 16: no longer affine to CPU3
[  552.505665] smpboot: CPU 3 is now offline
[  552.509421] ACPI: Low-level resume complete
[  552.509491] ACPI: EC: EC started
[  552.509492] PM: Restoring platform NVS memory
[  552.509874] Enabling non-boot CPUs ...
[  552.509928] x86: Booting SMP configuration:
[  552.509929] smpboot: Booting Node 0 Processor 1 APIC 0x4
[  552.512259]  cache: parent cpu1 should not be sleeping
[  552.512579] CPU1 is up
[  552.512612] smpboot: Booting Node 0 Processor 2 APIC 0x1
[  552.514946]  cache: parent cpu2 should not be sleeping
[  552.515302] CPU2 is up
[  552.515340] smpboot: Booting Node 0 Processor 3 APIC 0x5
[  552.517665]  cache: parent cpu3 should not be sleeping
[  552.518030] CPU3 is up
[  552.519988] ACPI: Waking up from system sleep state S3
[  552.529746] ACPI: EC: interrupt unblocked
[  552.553523] sdhci-pci 0000:03:00.0: MMC controller base frequency changed to 50Mhz.
[  552.555796] ACPI: EC: event unblocked
[  552.559025] sd 0:0:0:0: [sda] Starting disk
[  552.559027] sd 1:0:0:0: [sdb] Starting disk
[  552.601314] /dev/vmmon[0]: HostIFReadUptimeWork: detected settimeofday: fixed uptimeBase old 18445206031276062068 new 18445206026241062126 attempts 1
[  552.805406] usb 1-1.4: reset high-speed USB device number 3 using ehci-pci
[  552.809410] usb 2-1.1: reset full-speed USB device number 3 using ehci-pci
[  552.904677] ata5: SATA link down (SStatus 0 SControl 300)
[  552.905068] ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[  552.905099] ata6: SATA link down (SStatus 0 SControl 300)
[  552.985212] ata1.00: ACPI cmd 00/00:00:00:00:00:a0 (NOP) rejected by device (Stat=0x51 Err=0x04)
[  552.996425] ata1.00: ACPI cmd 00/00:00:00:00:00:a0 (NOP) rejected by device (Stat=0x51 Err=0x04)
[  552.997410] usb 2-1.7: reset full-speed USB device number 4 using ehci-pci
[  553.000470] ata1.00: configured for UDMA/133
[  553.004836] dell_wmi: Unknown key with type 0x0011 and code 0xffd0 pressed
[  553.134070] firewire_core 0000:03:00.4: rediscovered device fw0
[  553.141675] OOM killer enabled.
[  553.141676] Restarting tasks ...
[  553.141760] pci_bus 0000:0b: Allocating resources
[  553.141782] pci 0000:00:1e.0: PCI bridge to [bus 0b]
[  553.141786] pci 0000:00:1e.0:   bridge window [io  0x8000-0x8fff]
[  553.141792] pci 0000:00:1e.0:   bridge window [mem 0xf7200000-0xf73fffff]
[  553.141797] pci 0000:00:1e.0:   bridge window [mem 0xf7400000-0xf75fffff 64bit pref]
[  553.154538] done.
[  553.197102] pci 0000:00:1e.0: PCI bridge to [bus 0b]
[  553.197108] pci 0000:00:1e.0:   bridge window [io  0x8000-0x8fff]
[  553.197114] pci 0000:00:1e.0:   bridge window [mem 0xf7200000-0xf73fffff]
[  553.197117] pci 0000:00:1e.0:   bridge window [mem 0xf7400000-0xf75fffff 64bit pref]
[  553.197141] pci 0000:00:1e.0: PCI bridge to [bus 0b]
[  553.197143] pci 0000:00:1e.0:   bridge window [io  0x8000-0x8fff]
[  553.197147] pci 0000:00:1e.0:   bridge window [mem 0xf7200000-0xf73fffff]
[  553.197151] pci 0000:00:1e.0:   bridge window [mem 0xf7400000-0xf75fffff 64bit pref]
[  553.197589] pci_bus 0000:01: Allocating resources
[  553.197606] pci_bus 0000:02: Allocating resources
[  553.197630] pci_bus 0000:03: Allocating resources
[  553.197697] pci_bus 0000:05: Allocating resources
[  553.197709] pci 0000:00:1e.0: PCI bridge to [bus 0b]
[  553.197712] pci 0000:00:1e.0:   bridge window [io  0x8000-0x8fff]
[  553.197717] pci 0000:00:1e.0:   bridge window [mem 0xf7200000-0xf73fffff]
[  553.197720] pci 0000:00:1e.0:   bridge window [mem 0xf7400000-0xf75fffff 64bit pref]
[  553.197742] pci 0000:00:1e.0: PCI bridge to [bus 0b]
[  553.197745] pci 0000:00:1e.0:   bridge window [io  0x8000-0x8fff]
[  553.197750] pci 0000:00:1e.0:   bridge window [mem 0xf7200000-0xf73fffff]
[  553.197753] pci 0000:00:1e.0:   bridge window [mem 0xf7400000-0xf75fffff 64bit pref]
[  553.197813] pci 0000:00:1e.0: PCI bridge to [bus 0b]
[  553.197815] pci 0000:00:1e.0:   bridge window [io  0x8000-0x8fff]
[  553.197820] pci 0000:00:1e.0:   bridge window [mem 0xf7200000-0xf73fffff]
[  553.197824] pci 0000:00:1e.0:   bridge window [mem 0xf7400000-0xf75fffff 64bit pref]
[  553.197864] pci 0000:00:1e.0: PCI bridge to [bus 0b]
[  553.197866] pci 0000:00:1e.0:   bridge window [io  0x8000-0x8fff]
[  553.197871] pci 0000:00:1e.0:   bridge window [mem 0xf7200000-0xf73fffff]
[  553.197875] pci 0000:00:1e.0:   bridge window [mem 0xf7400000-0xf75fffff 64bit pref]
[  553.197955] pci 0000:00:1e.0: PCI bridge to [bus 0b]
[  553.197958] pci 0000:00:1e.0:   bridge window [io  0x8000-0x8fff]
[  553.197963] pci 0000:00:1e.0:   bridge window [mem 0xf7200000-0xf73fffff]
[  553.197966] pci 0000:00:1e.0:   bridge window [mem 0xf7400000-0xf75fffff 64bit pref]
[  553.225539] acpi PNP0401:00: Already enumerated
[  553.239737] acpi PNP0501:01: Still not present
[  553.287464] video LNXVIDEO:01: Restoring backlight state
[  553.293071] PM: suspend exit
[  553.341380] ata2: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[  553.353727] ata2.00: configured for UDMA/100
[  553.537139] dell_wmi: Unknown key with type 0x0011 and code 0xffd1 pressed
[  553.569343] e1000e: eno1 NIC Link is Down
[  553.570624] IPv6: ADDRCONF(NETDEV_UP): eno1: link is not ready
[  553.793548] IPv6: ADDRCONF(NETDEV_UP): eno1: link is not ready
[  553.795486] IPv6: ADDRCONF(NETDEV_UP): wlp2s0b1: link is not ready
[  553.865918] brcmsmac bcma0:1: brcms_ops_bss_info_changed: qos enabled: false (implement)
[  553.865934] brcmsmac bcma0:1: brcms_ops_config: change power-save mode: false (implement)
[  553.866245] IPv6: ADDRCONF(NETDEV_UP): wlp2s0b1: link is not ready
[  553.952481] brcmsmac bcma0:1: brcms_ops_bss_info_changed: qos enabled: false (implement)
[  553.952499] brcmsmac bcma0:1: brcms_ops_config: change power-save mode: false (implement)
[  553.952778] IPv6: ADDRCONF(NETDEV_UP): wlp2s0b1: link is not ready
[  554.028538] IPv6: ADDRCONF(NETDEV_UP): wlp2s0b1: link is not ready
[  555.009951] brcmsmac bcma0:1: brcms_ops_bss_info_changed: qos enabled: false (implement)
[  555.009970] brcmsmac bcma0:1: brcms_ops_config: change power-save mode: false (implement)
[  555.010247] IPv6: ADDRCONF(NETDEV_UP): wlp2s0b1: link is not ready
[  555.953929] wlp2s0b1: authenticate with b8:62:1f:50:76:24
[  555.953984] wlp2s0b1: send auth to b8:62:1f:50:76:24 (try 1/3)
[  555.955537] wlp2s0b1: authenticated
[  555.957272] wlp2s0b1: associate with b8:62:1f:50:76:24 (try 1/3)
[  555.960704] wlp2s0b1: RX AssocResp from b8:62:1f:50:76:24 (capab=0x411 status=0 aid=3)
[  555.961625] brcmsmac bcma0:1: brcmsmac: brcms_ops_bss_info_changed: associated
[  555.961634] brcmsmac bcma0:1: brcms_ops_bss_info_changed: qos enabled: true (implement)
[  555.961648] wlp2s0b1: associated
[  555.968810] brcmsmac bcma0:1: wl0: brcms_c_d11hdrs_mac80211:  txop exceeded phylen 159/256 dur 1778/1504
[  555.977149] brcmsmac bcma0:1: wl0: brcms_c_d11hdrs_mac80211:  txop exceeded phylen 137/256 dur 1602/1504
[  555.977421] IPv6: ADDRCONF(NETDEV_CHANGE): wlp2s0b1: link becomes ready
[  555.977796] /dev/vmnet: open called by PID 1117 (vmnet-bridge)
[  555.977806] /dev/vmnet: hub 0 does not exist, allocating memory.
[  555.977828] /dev/vmnet: port on hub 0 successfully opened
[  555.977838] bridge-wlp2s0b1: device is wireless, enabling SMAC
[  555.977843] bridge-wlp2s0b1: up
[  555.977961] bridge-wlp2s0b1: attached
[  555.986603] brcmsmac bcma0:1: brcms_ops_bss_info_changed: arp filtering: 1 addresses (implement)
[  556.177709] userif-2: sent link down event.
[  556.177713] userif-2: sent link up event.
[ 1046.251539] pci_bus 0000:0b: Allocating resources
[ 1046.251574] pci 0000:00:1e.0: PCI bridge to [bus 0b]
[ 1046.251581] pci 0000:00:1e.0:   bridge window [io  0x8000-0x8fff]
[ 1046.251590] pci 0000:00:1e.0:   bridge window [mem 0xf7200000-0xf73fffff]
[ 1046.251598] pci 0000:00:1e.0:   bridge window [mem 0xf7400000-0xf75fffff 64bit pref]
[ 1046.256545] pci 0000:00:1e.0: PCI bridge to [bus 0b]
[ 1046.256552] pci 0000:00:1e.0:   bridge window [io  0x8000-0x8fff]
[ 1046.256560] pci 0000:00:1e.0:   bridge window [mem 0xf7200000-0xf73fffff]
[ 1046.256564] pci 0000:00:1e.0:   bridge window [mem 0xf7400000-0xf75fffff 64bit pref]
[ 1046.256603] pci 0000:00:1e.0: PCI bridge to [bus 0b]
[ 1046.256607] pci 0000:00:1e.0:   bridge window [io  0x8000-0x8fff]
[ 1046.256613] pci 0000:00:1e.0:   bridge window [mem 0xf7200000-0xf73fffff]
[ 1046.256618] pci 0000:00:1e.0:   bridge window [mem 0xf7400000-0xf75fffff 64bit pref]
[ 1046.256962] pci_bus 0000:01: Allocating resources
[ 1046.256981] pci_bus 0000:02: Allocating resources
[ 1046.257004] pci_bus 0000:03: Allocating resources
[ 1046.257076] pci_bus 0000:05: Allocating resources
[ 1046.257092] pci 0000:00:1e.0: PCI bridge to [bus 0b]
[ 1046.257096] pci 0000:00:1e.0:   bridge window [io  0x8000-0x8fff]
[ 1046.257103] pci 0000:00:1e.0:   bridge window [mem 0xf7200000-0xf73fffff]
[ 1046.257107] pci 0000:00:1e.0:   bridge window [mem 0xf7400000-0xf75fffff 64bit pref]
[ 1046.257143] pci 0000:00:1e.0: PCI bridge to [bus 0b]
[ 1046.257147] pci 0000:00:1e.0:   bridge window [io  0x8000-0x8fff]
[ 1046.257154] pci 0000:00:1e.0:   bridge window [mem 0xf7200000-0xf73fffff]
[ 1046.257159] pci 0000:00:1e.0:   bridge window [mem 0xf7400000-0xf75fffff 64bit pref]
[ 1046.257251] pci 0000:00:1e.0: PCI bridge to [bus 0b]
[ 1046.257255] pci 0000:00:1e.0:   bridge window [io  0x8000-0x8fff]
[ 1046.257261] pci 0000:00:1e.0:   bridge window [mem 0xf7200000-0xf73fffff]
[ 1046.257266] pci 0000:00:1e.0:   bridge window [mem 0xf7400000-0xf75fffff 64bit pref]
[ 1046.257332] pci 0000:00:1e.0: PCI bridge to [bus 0b]
[ 1046.257336] pci 0000:00:1e.0:   bridge window [io  0x8000-0x8fff]
[ 1046.257342] pci 0000:00:1e.0:   bridge window [mem 0xf7200000-0xf73fffff]
[ 1046.257347] pci 0000:00:1e.0:   bridge window [mem 0xf7400000-0xf75fffff 64bit pref]
[ 1046.257477] pci 0000:00:1e.0: PCI bridge to [bus 0b]
[ 1046.257481] pci 0000:00:1e.0:   bridge window [io  0x8000-0x8fff]
[ 1046.257487] pci 0000:00:1e.0:   bridge window [mem 0xf7200000-0xf73fffff]
[ 1046.257492] pci 0000:00:1e.0:   bridge window [mem 0xf7400000-0xf75fffff 64bit pref]
[ 1046.269474] dell_wmi: Unknown key with type 0x0011 and code 0xffd0 pressed
[ 1046.822159] brcmsmac bcma0:1: brcms_ops_bss_info_changed: arp filtering: 0 addresses (implement)
[ 1046.822604] wlp2s0b1: deauthenticating from b8:62:1f:50:76:24 by local choice (Reason: 3=DEAUTH_LEAVING)
[ 1046.827738] brcmsmac bcma0:1: brcmsmac: brcms_ops_bss_info_changed: disassociated
[ 1046.827746] brcmsmac bcma0:1: brcms_ops_bss_info_changed: qos enabled: false (implement)
[ 1046.845930] bridge-wlp2s0b1: disabling the bridge on dev down
[ 1046.845971] bridge-wlp2s0b1: down
[ 1046.912677] brcmsmac bcma0:1: brcms_ops_bss_info_changed: qos enabled: false (implement)
[ 1046.912693] brcmsmac bcma0:1: brcms_ops_config: change power-save mode: false (implement)
[ 1046.912947] IPv6: ADDRCONF(NETDEV_UP): wlp2s0b1: link is not ready
[ 1046.912956] bridge-wlp2s0b1: enabling the bridge on dev up
[ 1046.912963] bridge-wlp2s0b1: device is wireless, enabling SMAC
[ 1046.912967] bridge-wlp2s0b1: up
[ 1046.913323] bridge-wlp2s0b1: disabling the bridge on dev down
[ 1046.913370] bridge-wlp2s0b1: down
[ 1046.913389] bridge-wlp2s0b1: detached
[ 1046.913508] /dev/vmnet: open called by PID 1117 (vmnet-bridge)
[ 1046.913520] /dev/vmnet: hub 0 does not exist, allocating memory.
[ 1046.913576] /dev/vmnet: port on hub 0 successfully opened
[ 1046.913591] bridge-wlp2s0b1: device is wireless, enabling SMAC
[ 1046.913596] bridge-wlp2s0b1: up
[ 1046.913600] bridge-wlp2s0b1: attached
[ 1046.913669] bridge-wlp2s0b1: disabling the bridge on dev down
[ 1046.913747] bridge-wlp2s0b1: down
[ 1046.913762] bridge-wlp2s0b1: detached
[ 1046.966475] PM: suspend entry (deep)
[ 1046.966478] PM: Syncing filesystems ...
[ 1047.023599] userif-2: sent link down event.
[ 1047.023601] userif-2: sent link up event.
[ 1047.148947] done.
[ 1047.149295] (NULL device *): firmware: direct-loading firmware brcm/bcm43xx_hdr-0.fw
[ 1047.149336] (NULL device *): firmware: direct-loading firmware brcm/bcm43xx-0.fw
[ 1047.149373] Freezing user space processes ... (elapsed 0.323 seconds) done.
[ 1047.472865] OOM killer disabled.
[ 1047.472867] Freezing remaining freezable tasks ... (elapsed 0.001 seconds) done.
[ 1047.474201] Suspending console(s) (use no_console_suspend to debug)
[ 1047.491887] sd 0:0:0:0: [sda] Synchronizing SCSI cache
[ 1047.491899] sd 1:0:0:0: [sdb] Synchronizing SCSI cache
[ 1047.491954] sd 0:0:0:0: [sda] Stopping disk
[ 1047.491967] sd 1:0:0:0: [sdb] Stopping disk
[ 1047.493756] e1000e: EEE TX LPI TIMER: 00000000
[ 1048.588024] ACPI: EC: interrupt blocked
[ 1048.607763] ACPI: Preparing to enter system sleep state S3
[ 1048.610625] ACPI: EC: event blocked
[ 1048.610626] ACPI: EC: EC stopped
[ 1048.610627] PM: Saving platform NVS memory
[ 1048.610648] Disabling non-boot CPUs ...
[ 1048.623890] IRQ 25: no longer affine to CPU1
[ 1048.624906] smpboot: CPU 1 is now offline
[ 1048.647876] IRQ 26: no longer affine to CPU2
[ 1048.649067] smpboot: CPU 2 is now offline
[ 1048.679764] IRQ 16: no longer affine to CPU3
[ 1048.680784] smpboot: CPU 3 is now offline
[ 1048.683230] ACPI: Low-level resume complete
[ 1048.683302] ACPI: EC: EC started
[ 1048.683302] PM: Restoring platform NVS memory
[ 1048.683687] Enabling non-boot CPUs ...
[ 1048.683740] x86: Booting SMP configuration:
[ 1048.683741] smpboot: Booting Node 0 Processor 1 APIC 0x4
[ 1048.686189]  cache: parent cpu1 should not be sleeping
[ 1048.686506] CPU1 is up
[ 1048.686540] smpboot: Booting Node 0 Processor 2 APIC 0x1
[ 1048.688903]  cache: parent cpu2 should not be sleeping
[ 1048.689252] CPU2 is up
[ 1048.689289] smpboot: Booting Node 0 Processor 3 APIC 0x5
[ 1048.691615]  cache: parent cpu3 should not be sleeping
[ 1048.691981] CPU3 is up
[ 1048.693950] ACPI: Waking up from system sleep state S3
[ 1048.704706] ACPI: EC: interrupt unblocked
[ 1048.725260] sdhci-pci 0000:03:00.0: MMC controller base frequency changed to 50Mhz.
[ 1048.727779] ACPI: EC: event unblocked
[ 1048.730194] sd 0:0:0:0: [sda] Starting disk
[ 1048.730196] sd 1:0:0:0: [sdb] Starting disk
[ 1048.972405] usb 1-1.4: reset high-speed USB device number 3 using ehci-pci
[ 1048.988371] usb 2-1.7: reset full-speed USB device number 4 using ehci-pci
[ 1049.064309] /dev/vmmon[0]: HostIFReadUptimeWork: detected settimeofday: fixed uptimeBase old 18445206026241062126 new 18445206023529400941 attempts 1
[ 1049.079653] ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 1049.079690] ata5: SATA link down (SStatus 0 SControl 300)
[ 1049.079721] ata6: SATA link down (SStatus 0 SControl 300)
[ 1049.162940] ata1.00: ACPI cmd 00/00:00:00:00:00:a0 (NOP) rejected by device (Stat=0x51 Err=0x04)
[ 1049.174085] ata1.00: ACPI cmd 00/00:00:00:00:00:a0 (NOP) rejected by device (Stat=0x51 Err=0x04)
[ 1049.176279] usb 2-1.1: reset full-speed USB device number 3 using ehci-pci
[ 1049.178132] ata1.00: configured for UDMA/133
[ 1049.178710] dell_wmi: Unknown key with type 0x0011 and code 0xffd0 pressed
[ 1049.288329] firewire_core 0000:03:00.4: rediscovered device fw0
[ 1049.326076] OOM killer enabled.
[ 1049.326081] Restarting tasks ...
[ 1049.326181] pci_bus 0000:0b: Allocating resources
[ 1049.326205] pci 0000:00:1e.0: PCI bridge to [bus 0b]
[ 1049.326209] pci 0000:00:1e.0:   bridge window [io  0x8000-0x8fff]
[ 1049.326215] pci 0000:00:1e.0:   bridge window [mem 0xf7200000-0xf73fffff]
[ 1049.326218] pci 0000:00:1e.0:   bridge window [mem 0xf7400000-0xf75fffff 64bit pref]
[ 1049.334454] done.
[ 1049.431624] pci 0000:00:1e.0: PCI bridge to [bus 0b]
[ 1049.431630] pci 0000:00:1e.0:   bridge window [io  0x8000-0x8fff]
[ 1049.431636] pci 0000:00:1e.0:   bridge window [mem 0xf7200000-0xf73fffff]
[ 1049.431641] pci 0000:00:1e.0:   bridge window [mem 0xf7400000-0xf75fffff 64bit pref]
[ 1049.431671] pci 0000:00:1e.0: PCI bridge to [bus 0b]
[ 1049.431674] pci 0000:00:1e.0:   bridge window [io  0x8000-0x8fff]
[ 1049.431679] pci 0000:00:1e.0:   bridge window [mem 0xf7200000-0xf73fffff]
[ 1049.431684] pci 0000:00:1e.0:   bridge window [mem 0xf7400000-0xf75fffff 64bit pref]
[ 1049.431995] pci_bus 0000:01: Allocating resources
[ 1049.432015] pci_bus 0000:02: Allocating resources
[ 1049.432035] pci_bus 0000:03: Allocating resources
[ 1049.432108] pci_bus 0000:05: Allocating resources
[ 1049.432121] pci 0000:00:1e.0: PCI bridge to [bus 0b]
[ 1049.432124] pci 0000:00:1e.0:   bridge window [io  0x8000-0x8fff]
[ 1049.432133] pci 0000:00:1e.0:   bridge window [mem 0xf7200000-0xf73fffff]
[ 1049.432137] pci 0000:00:1e.0:   bridge window [mem 0xf7400000-0xf75fffff 64bit pref]
[ 1049.432182] pci 0000:00:1e.0: PCI bridge to [bus 0b]
[ 1049.432187] pci 0000:00:1e.0:   bridge window [io  0x8000-0x8fff]
[ 1049.432195] pci 0000:00:1e.0:   bridge window [mem 0xf7200000-0xf73fffff]
[ 1049.432199] pci 0000:00:1e.0:   bridge window [mem 0xf7400000-0xf75fffff 64bit pref]
[ 1049.432276] pci 0000:00:1e.0: PCI bridge to [bus 0b]
[ 1049.432280] pci 0000:00:1e.0:   bridge window [io  0x8000-0x8fff]
[ 1049.432286] pci 0000:00:1e.0:   bridge window [mem 0xf7200000-0xf73fffff]
[ 1049.432290] pci 0000:00:1e.0:   bridge window [mem 0xf7400000-0xf75fffff 64bit pref]
[ 1049.432345] pci 0000:00:1e.0: PCI bridge to [bus 0b]
[ 1049.432348] pci 0000:00:1e.0:   bridge window [io  0x8000-0x8fff]
[ 1049.432354] pci 0000:00:1e.0:   bridge window [mem 0xf7200000-0xf73fffff]
[ 1049.432359] pci 0000:00:1e.0:   bridge window [mem 0xf7400000-0xf75fffff 64bit pref]
[ 1049.432466] pci 0000:00:1e.0: PCI bridge to [bus 0b]
[ 1049.432469] pci 0000:00:1e.0:   bridge window [io  0x8000-0x8fff]
[ 1049.432475] pci 0000:00:1e.0:   bridge window [mem 0xf7200000-0xf73fffff]
[ 1049.432480] pci 0000:00:1e.0:   bridge window [mem 0xf7400000-0xf75fffff 64bit pref]
[ 1049.442071] acpi PNP0401:00: Already enumerated
[ 1049.456331] acpi PNP0501:01: Still not present
[ 1049.460197] ata2: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 1049.472413] ata2.00: configured for UDMA/100
[ 1049.507976] video LNXVIDEO:01: Restoring backlight state
[ 1049.535514] PM: suspend exit
[ 1049.789077] dell_wmi: Unknown key with type 0x0011 and code 0xffd1 pressed
[ 1049.791185] e1000e: eno1 NIC Link is Down
[ 1049.793599] IPv6: ADDRCONF(NETDEV_UP): eno1: link is not ready
[ 1050.016298] IPv6: ADDRCONF(NETDEV_UP): eno1: link is not ready
[ 1050.025737] IPv6: ADDRCONF(NETDEV_UP): wlp2s0b1: link is not ready
[ 1050.094373] brcmsmac bcma0:1: brcms_ops_bss_info_changed: qos enabled: false (implement)
[ 1050.094389] brcmsmac bcma0:1: brcms_ops_config: change power-save mode: false (implement)
[ 1050.094694] IPv6: ADDRCONF(NETDEV_UP): wlp2s0b1: link is not ready
[ 1050.182441] brcmsmac bcma0:1: brcms_ops_bss_info_changed: qos enabled: false (implement)
[ 1050.182458] brcmsmac bcma0:1: brcms_ops_config: change power-save mode: false (implement)
[ 1050.182720] IPv6: ADDRCONF(NETDEV_UP): wlp2s0b1: link is not ready
[ 1050.236139] IPv6: ADDRCONF(NETDEV_UP): wlp2s0b1: link is not ready
[ 1051.221306] brcmsmac bcma0:1: brcms_ops_bss_info_changed: qos enabled: false (implement)
[ 1051.221322] brcmsmac bcma0:1: brcms_ops_config: change power-save mode: false (implement)
[ 1051.221678] IPv6: ADDRCONF(NETDEV_UP): wlp2s0b1: link is not ready
[ 1052.136231] wlp2s0b1: authenticate with b8:62:1f:50:76:24
[ 1052.136301] wlp2s0b1: send auth to b8:62:1f:50:76:24 (try 1/3)
[ 1052.137901] wlp2s0b1: authenticated
[ 1052.139275] wlp2s0b1: associate with b8:62:1f:50:76:24 (try 1/3)
[ 1052.142577] wlp2s0b1: RX AssocResp from b8:62:1f:50:76:24 (capab=0x411 status=0 aid=1)
[ 1052.143297] brcmsmac bcma0:1: brcmsmac: brcms_ops_bss_info_changed: associated
[ 1052.143304] brcmsmac bcma0:1: brcms_ops_bss_info_changed: qos enabled: true (implement)
[ 1052.143318] wlp2s0b1: associated
[ 1052.148439] brcmsmac bcma0:1: wl0: brcms_c_d11hdrs_mac80211:  txop exceeded phylen 159/256 dur 1778/1504
[ 1052.156834] brcmsmac bcma0:1: wl0: brcms_c_d11hdrs_mac80211:  txop exceeded phylen 137/256 dur 1602/1504
[ 1052.157198] IPv6: ADDRCONF(NETDEV_CHANGE): wlp2s0b1: link becomes ready
[ 1052.157643] /dev/vmnet: open called by PID 1117 (vmnet-bridge)
[ 1052.157654] /dev/vmnet: hub 0 does not exist, allocating memory.
[ 1052.157680] /dev/vmnet: port on hub 0 successfully opened
[ 1052.157696] bridge-wlp2s0b1: device is wireless, enabling SMAC
[ 1052.157700] bridge-wlp2s0b1: up
[ 1052.157861] bridge-wlp2s0b1: attached
[ 1052.166689] brcmsmac bcma0:1: brcms_ops_bss_info_changed: arp filtering: 1 addresses (implement)
[ 1052.357481] userif-2: sent link down event.
[ 1052.357484] userif-2: sent link up event.
[ 1075.276352] perf: interrupt took too long (2513 > 2500), lowering kernel.perf_event_max_sample_rate to 79500
[ 1315.141275] perf: interrupt took too long (3147 > 3141), lowering kernel.perf_event_max_sample_rate to 63500
[ 1701.573509] brcmsmac bcma0:1: brcms_ops_bss_info_changed: arp filtering: 0 addresses (implement)
[ 1701.573906] wlp2s0b1: deauthenticating from b8:62:1f:50:76:24 by local choice (Reason: 3=DEAUTH_LEAVING)
[ 1701.578131] brcmsmac bcma0:1: brcmsmac: brcms_ops_bss_info_changed: disassociated
[ 1701.578141] brcmsmac bcma0:1: brcms_ops_bss_info_changed: qos enabled: false (implement)
[ 1701.610100] bridge-wlp2s0b1: disabling the bridge on dev down
[ 1701.610150] bridge-wlp2s0b1: down
[ 1701.679766] brcmsmac bcma0:1: brcms_ops_bss_info_changed: qos enabled: false (implement)
[ 1701.679784] brcmsmac bcma0:1: brcms_ops_config: change power-save mode: false (implement)
[ 1701.680048] IPv6: ADDRCONF(NETDEV_UP): wlp2s0b1: link is not ready
[ 1701.680060] bridge-wlp2s0b1: enabling the bridge on dev up
[ 1701.680067] bridge-wlp2s0b1: device is wireless, enabling SMAC
[ 1701.680074] bridge-wlp2s0b1: up
[ 1701.680239] bridge-wlp2s0b1: disabling the bridge on dev down
[ 1701.680335] bridge-wlp2s0b1: down
[ 1701.680350] bridge-wlp2s0b1: detached
[ 1701.739881] PM: suspend entry (deep)
[ 1701.739885] PM: Syncing filesystems ...
[ 1701.774108] userif-2: sent link down event.
[ 1701.774112] userif-2: sent link up event.
[ 1701.977376] done.
[ 1701.977733] (NULL device *): firmware: direct-loading firmware brcm/bcm43xx_hdr-0.fw
[ 1701.977771] (NULL device *): firmware: direct-loading firmware brcm/bcm43xx-0.fw
[ 1701.977785] Freezing user space processes ... (elapsed 0.002 seconds) done.
[ 1701.980060] OOM killer disabled.
[ 1701.980061] Freezing remaining freezable tasks ... (elapsed 0.001 seconds) done.
[ 1701.981369] Suspending console(s) (use no_console_suspend to debug)
[ 1701.997468] e1000e: EEE TX LPI TIMER: 00000000
[ 1702.004556] sd 1:0:0:0: [sdb] Synchronizing SCSI cache
[ 1702.004576] sd 0:0:0:0: [sda] Synchronizing SCSI cache
[ 1702.004956] sd 0:0:0:0: [sda] Stopping disk
[ 1702.011792] dell_wmi: Unknown key with type 0x0011 and code 0xffd0 pressed
[ 1702.249973] sd 1:0:0:0: [sdb] Stopping disk
[ 1703.316839] ACPI: EC: interrupt blocked
[ 1703.336751] ACPI: Preparing to enter system sleep state S3
[ 1703.339457] ACPI: EC: event blocked
[ 1703.339458] ACPI: EC: EC stopped
[ 1703.339459] PM: Saving platform NVS memory
[ 1703.339479] Disabling non-boot CPUs ...
[ 1703.352906] IRQ 25: no longer affine to CPU1
[ 1703.353926] smpboot: CPU 1 is now offline
[ 1703.376858] IRQ 26: no longer affine to CPU2
[ 1703.378037] smpboot: CPU 2 is now offline
[ 1703.400775] IRQ 16: no longer affine to CPU3
[ 1703.401791] smpboot: CPU 3 is now offline
[ 1703.404173] ACPI: Low-level resume complete
[ 1703.404252] ACPI: EC: EC started
[ 1703.404252] PM: Restoring platform NVS memory
[ 1703.404671] Enabling non-boot CPUs ...
[ 1703.404732] x86: Booting SMP configuration:
[ 1703.404733] smpboot: Booting Node 0 Processor 1 APIC 0x4
[ 1703.407114]  cache: parent cpu1 should not be sleeping
[ 1703.407492] CPU1 is up
[ 1703.407529] smpboot: Booting Node 0 Processor 2 APIC 0x1
[ 1703.409915]  cache: parent cpu2 should not be sleeping
[ 1703.410316] CPU2 is up
[ 1703.410363] smpboot: Booting Node 0 Processor 3 APIC 0x5
[ 1703.412829]  cache: parent cpu3 should not be sleeping
[ 1703.413260] CPU3 is up
[ 1703.415400] ACPI: Waking up from system sleep state S3
[ 1703.418884] ACPI: EC: interrupt unblocked
[ 1703.438706] sdhci-pci 0000:03:00.0: MMC controller base frequency changed to 50Mhz.
[ 1703.441385] ACPI: EC: event unblocked
[ 1703.444966] sd 1:0:0:0: [sdb] Starting disk
[ 1703.444969] sd 0:0:0:0: [sda] Starting disk
[ 1703.450238] ACPI: button: The lid device is not compliant to SW_LID.
[ 1703.689612] usb 1-1.4: reset high-speed USB device number 3 using ehci-pci
[ 1703.697605] usb 2-1.1: reset full-speed USB device number 3 using ehci-pci
[ 1703.792843] ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 1703.792885] ata5: SATA link down (SStatus 0 SControl 300)
[ 1703.792918] ata6: SATA link down (SStatus 0 SControl 300)
[ 1703.879360] ata1.00: ACPI cmd 00/00:00:00:00:00:a0 (NOP) rejected by device (Stat=0x51 Err=0x04)
[ 1703.889547] usb 2-1.7: reset full-speed USB device number 4 using ehci-pci
[ 1703.892974] ata1.00: ACPI cmd 00/00:00:00:00:00:a0 (NOP) rejected by device (Stat=0x51 Err=0x04)
[ 1703.897080] ata1.00: configured for UDMA/133
[ 1704.005577] firewire_core 0000:03:00.4: rediscovered device fw0
[ 1704.111600] dell_wmi: Unknown key with type 0x0011 and code 0xffd0 pressed
[ 1704.177506] ata2: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 1704.190040] ata2.00: configured for UDMA/100
[ 1704.199846] OOM killer enabled.
[ 1704.199847] Restarting tasks ...
[ 1704.199937] pci_bus 0000:0b: Allocating resources
[ 1704.199963] pci 0000:00:1e.0: PCI bridge to [bus 0b]
[ 1704.199968] pci 0000:00:1e.0:   bridge window [io  0x8000-0x8fff]
[ 1704.199977] pci 0000:00:1e.0:   bridge window [mem 0xf7200000-0xf73fffff]
[ 1704.199984] pci 0000:00:1e.0:   bridge window [mem 0xf7400000-0xf75fffff 64bit pref]
[ 1704.248325] done.
[ 1704.282709] pci 0000:00:1e.0: PCI bridge to [bus 0b]
[ 1704.282716] pci 0000:00:1e.0:   bridge window [io  0x8000-0x8fff]
[ 1704.282726] pci 0000:00:1e.0:   bridge window [mem 0xf7200000-0xf73fffff]
[ 1704.282729] pci 0000:00:1e.0:   bridge window [mem 0xf7400000-0xf75fffff 64bit pref]
[ 1704.282765] pci 0000:00:1e.0: PCI bridge to [bus 0b]
[ 1704.282768] pci 0000:00:1e.0:   bridge window [io  0x8000-0x8fff]
[ 1704.282773] pci 0000:00:1e.0:   bridge window [mem 0xf7200000-0xf73fffff]
[ 1704.282777] pci 0000:00:1e.0:   bridge window [mem 0xf7400000-0xf75fffff 64bit pref]
[ 1704.283108] pci_bus 0000:01: Allocating resources
[ 1704.283125] pci_bus 0000:02: Allocating resources
[ 1704.283152] pci_bus 0000:03: Allocating resources
[ 1704.283223] pci_bus 0000:05: Allocating resources
[ 1704.283241] pci 0000:00:1e.0: PCI bridge to [bus 0b]
[ 1704.283244] pci 0000:00:1e.0:   bridge window [io  0x8000-0x8fff]
[ 1704.283249] pci 0000:00:1e.0:   bridge window [mem 0xf7200000-0xf73fffff]
[ 1704.283253] pci 0000:00:1e.0:   bridge window [mem 0xf7400000-0xf75fffff 64bit pref]
[ 1704.283285] pci 0000:00:1e.0: PCI bridge to [bus 0b]
[ 1704.283288] pci 0000:00:1e.0:   bridge window [io  0x8000-0x8fff]
[ 1704.283293] pci 0000:00:1e.0:   bridge window [mem 0xf7200000-0xf73fffff]
[ 1704.283301] pci 0000:00:1e.0:   bridge window [mem 0xf7400000-0xf75fffff 64bit pref]
[ 1704.283375] pci 0000:00:1e.0: PCI bridge to [bus 0b]
[ 1704.283377] pci 0000:00:1e.0:   bridge window [io  0x8000-0x8fff]
[ 1704.283382] pci 0000:00:1e.0:   bridge window [mem 0xf7200000-0xf73fffff]
[ 1704.283386] pci 0000:00:1e.0:   bridge window [mem 0xf7400000-0xf75fffff 64bit pref]
[ 1704.283435] pci 0000:00:1e.0: PCI bridge to [bus 0b]
[ 1704.283438] pci 0000:00:1e.0:   bridge window [io  0x8000-0x8fff]
[ 1704.283442] pci 0000:00:1e.0:   bridge window [mem 0xf7200000-0xf73fffff]
[ 1704.283446] pci 0000:00:1e.0:   bridge window [mem 0xf7400000-0xf75fffff 64bit pref]
[ 1704.283541] pci 0000:00:1e.0: PCI bridge to [bus 0b]
[ 1704.283543] pci 0000:00:1e.0:   bridge window [io  0x8000-0x8fff]
[ 1704.283548] pci 0000:00:1e.0:   bridge window [mem 0xf7200000-0xf73fffff]
[ 1704.283552] pci 0000:00:1e.0:   bridge window [mem 0xf7400000-0xf75fffff 64bit pref]
[ 1704.293463] /dev/vmmon[274]: HostIFReadUptimeWork: detected settimeofday: fixed uptimeBase old 18445206023529400941 new 18445206021347252938 attempts 1
[ 1704.330820] dell_wmi: Unknown key with type 0x0011 and code 0xffd1 pressed
[ 1704.350260] acpi PNP0401:00: Already enumerated
[ 1704.363276] acpi PNP0501:01: Still not present
[ 1704.377334] video LNXVIDEO:01: Restoring backlight state
[ 1704.380627] PM: suspend exit
[ 1704.705821] e1000e: eno1 NIC Link is Down
[ 1704.710826] IPv6: ADDRCONF(NETDEV_UP): eno1: link is not ready
[ 1704.937907] IPv6: ADDRCONF(NETDEV_UP): eno1: link is not ready
[ 1704.943808] IPv6: ADDRCONF(NETDEV_UP): wlp2s0b1: link is not ready
[ 1705.016269] brcmsmac bcma0:1: brcms_ops_bss_info_changed: qos enabled: false (implement)
[ 1705.016292] brcmsmac bcma0:1: brcms_ops_config: change power-save mode: false (implement)
[ 1705.016623] IPv6: ADDRCONF(NETDEV_UP): wlp2s0b1: link is not ready
[ 1705.106151] brcmsmac bcma0:1: brcms_ops_bss_info_changed: qos enabled: false (implement)
[ 1705.106175] brcmsmac bcma0:1: brcms_ops_config: change power-save mode: false (implement)
[ 1705.106556] IPv6: ADDRCONF(NETDEV_UP): wlp2s0b1: link is not ready
[ 1705.166589] IPv6: ADDRCONF(NETDEV_UP): wlp2s0b1: link is not ready
[ 1706.157493] brcmsmac bcma0:1: brcms_ops_bss_info_changed: qos enabled: false (implement)
[ 1706.157509] brcmsmac bcma0:1: brcms_ops_config: change power-save mode: false (implement)
[ 1706.157987] IPv6: ADDRCONF(NETDEV_UP): wlp2s0b1: link is not ready
[ 1707.082771] wlp2s0b1: authenticate with b8:62:1f:50:76:24
[ 1707.082843] wlp2s0b1: send auth to b8:62:1f:50:76:24 (try 1/3)
[ 1707.085148] wlp2s0b1: authenticated
[ 1707.089256] wlp2s0b1: associate with b8:62:1f:50:76:24 (try 1/3)
[ 1707.092606] wlp2s0b1: RX AssocResp from b8:62:1f:50:76:24 (capab=0x411 status=0 aid=3)
[ 1707.093370] brcmsmac bcma0:1: brcmsmac: brcms_ops_bss_info_changed: associated
[ 1707.093382] brcmsmac bcma0:1: brcms_ops_bss_info_changed: qos enabled: true (implement)
[ 1707.093400] wlp2s0b1: associated
[ 1707.101946] brcmsmac bcma0:1: wl0: brcms_c_d11hdrs_mac80211:  txop exceeded phylen 159/256 dur 1778/1504
[ 1707.109707] brcmsmac bcma0:1: wl0: brcms_c_d11hdrs_mac80211:  txop exceeded phylen 137/256 dur 1602/1504
[ 1707.110238] IPv6: ADDRCONF(NETDEV_CHANGE): wlp2s0b1: link becomes ready
[ 1707.111080] /dev/vmnet: open called by PID 1117 (vmnet-bridge)
[ 1707.111094] /dev/vmnet: hub 0 does not exist, allocating memory.
[ 1707.111143] /dev/vmnet: port on hub 0 successfully opened
[ 1707.111161] bridge-wlp2s0b1: device is wireless, enabling SMAC
[ 1707.111167] bridge-wlp2s0b1: up
[ 1707.111173] bridge-wlp2s0b1: attached
[ 1707.129866] brcmsmac bcma0:1: brcms_ops_bss_info_changed: arp filtering: 1 addresses (implement)
[ 1707.311018] userif-2: sent link down event.
[ 1707.311022] userif-2: sent link up event.
[ 1854.500309] perf: interrupt took too long (3944 > 3933), lowering kernel.perf_event_max_sample_rate to 50500
[ 2201.843187] usb 2-1.2: new high-speed USB device number 6 using ehci-pci
[ 2202.347243] usb 2-1.2: device not accepting address 6, error -71
[ 2202.635382] usb 2-1.2: new high-speed USB device number 7 using ehci-pci
[ 2202.752829] usb 2-1.2: New USB device found, idVendor=2717, idProduct=ff48
[ 2202.752834] usb 2-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2202.752837] usb 2-1.2: Product: SDM636-MTP _SN:0DBDEA19
[ 2202.752839] usb 2-1.2: Manufacturer: Xiaomi
[ 2202.752842] usb 2-1.2: SerialNumber: d2f5c2ae
[ 2202.797207] perf: interrupt took too long (4937 > 4930), lowering kernel.perf_event_max_sample_rate to 40500
[ 2207.252343] usb 2-1.2: USB disconnect, device number 7
[ 2207.547709] usb 2-1.2: new high-speed USB device number 8 using ehci-pci
[ 2207.868052] usb 2-1.2: New USB device found, idVendor=2717, idProduct=ff48
[ 2207.868057] usb 2-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2207.868061] usb 2-1.2: Product: SDM636-MTP _SN:0DBDEA19
[ 2207.868063] usb 2-1.2: Manufacturer: Xiaomi
[ 2207.868066] usb 2-1.2: SerialNumber: d2f5c2ae
Być może brakuje Ci czegoś do obsługi w trybie MTP.
Przełącz się na tryb pamięci masowej (jeśli masz taką możliwość).
korbielow
Takie mam opcje w Xiaomi Redmi Note 5
To da się coś z tym zrobić ?
Przesłać pliki.
korbielow
w trybie przeslac pliki mam "Nie można odnaleźć pasującego urządzenia biblioteki udev."
Co ciekawe jak wlacze VMware i uruchomie WIN 7 to przesyłanie plików działa bez problemu.
Zainstaluj biblioteki do mtp
korbielow
Chodzi o
apt-get install mtp-tools
Tak, i nie zapomnij odblokować telefonu przy podłączeniu :)
