Verifying archive integrity...Verifying archive integrity... All good.Uncompressing Instalacja systemu POMOST Std.......................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................
Wersja javy '1.6.0_22' OK.
Wyszukiwanie istniejącej instalacji serwera firebird. Proszę czekać...
Firebird zainstalowany w /usr/lib/firebird/2.1
Jeśli ta ścieżka jest błędna podaj poprawną jeśli nie naciśnij ENTER
./Instaluj.bash: line 101: /usr/lib/firebird/2.1/bin/fb_config: Nie ma takiego pliku ani katalogu
Czcionki dla systemu POMOST Std są zainstalowane w systemie.
Podaj ścieżkę instalacyjną lub wciśnij ENTER aby zainstalować w ścieżce domyślnej [ /opt/pomost ]
Kopiowanie plików instalacyjnych
mkdir: nie można utworzyć katalogu `/opt/pomost': Plik istnieje
Kopiowanie plików bazy ... OK
Kopiowanie plików aplikacji ... OK
Podaj hasło administratora bazy firebird lub naciśnij enter jeśli jest ono domyślne [ masterkey ]
Konfiguracja serwera Firebird exec: 11: /usr/lib/firebird/2.1/bin/isql.real: not found
OK
Tworzenie użytkownika pomost
Użytkownik pomost już istnieje
Czy serwer JBoss systemu POMOST Std ma być uruchamiany jako usługa systemowa [t/N]: T
update-rc.d: using dependency based boot sequencing
update-rc.d: warning: pomost start runlevel arguments (2 3 4 5) do not match LSB Default-Start values (3 5)
update-rc.d: warning: pomost stop runlevel arguments (0 1 6) do not match LSB Default-Stop values (0 1 2 6)
insserv: Script pomost is broken: incomplete LSB comment.
insserv: missing `Required-Start:' entry: please add even if empty.
insserv: missing `Required-Stop:' entry: please add even if empty.
