Wygląda to wszystko tak:
Główny host ma konfigurację:
root@PLHQSRDMZ01:~# cat /etc/network/interfaces
auto lo
iface lo inet loopback
auto bond0
iface bond0 inet manual
slaves eth5 eth6
bond-mode active-backup
bond-miimon 100
bond-downdelay 0
bond-updelay 0
auto br0
iface br0 inet static
address 10.50.12.100
netmask 255.255.255.0
gateway 10.50.12.1
network 10.50.10.0
bridge_ports bond0
bridge_fd 0
bridge_maxwait 0
bridge_stp off
root@PLHQSRDMZ01:~# ifconfig
bond0 Link encap:Ethernet HWaddr 08:00:27:95:e4:45
inet6 addr: fe80::a00:27ff:fe95:e445/64 Scope:Link
UP BROADCAST RUNNING MASTER MULTICAST MTU:1500 Metric:1
RX packets:515 errors:0 dropped:0 overruns:0 frame:0
TX packets:132 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:37405 (36.5 KiB) TX bytes:13712 (13.3 KiB)
br0 Link encap:Ethernet HWaddr 08:00:27:95:e4:45
inet addr:10.50.12.100 Bcast:10.50.12.255 Mask:255.255.255.0
RX packets:514 errors:0 dropped:0 overruns:0 frame:0
TX packets:126 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:27959 (27.3 KiB) TX bytes:13244 (12.9 KiB)
eth5 Link encap:Ethernet HWaddr 08:00:27:95:e4:45
UP BROADCAST RUNNING SLAVE MULTICAST MTU:1500 Metric:1
collisions:0 txqueuelen:1000
RX bytes:37345 (36.4 KiB) TX bytes:13712 (13.3 KiB)
eth6 Link encap:Ethernet HWaddr 08:00:27:95:e4:45
RX packets:1 errors:0 dropped:0 overruns:0 frame:0
RX bytes:60 (60.0 B) TX bytes:0 (0.0 B)
lo Link encap:Local Loopback
RX packets:8 errors:0 dropped:0 overruns:0 frame:0
TX packets:8 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:560 (560.0 B) TX bytes:560 (560.0 B)
root@PLHQSRDMZ01:~# cat /proc/net/bonding/bond0
Ethernet Channel Bonding Driver: v3.5.0 (November 4, 2008)
Bonding Mode: fault-tolerance (active-backup)
Primary Slave: None
Currently Active Slave: eth5
MII Status: up
MII Polling Interval (ms): 100
Up Delay (ms): 0
Down Delay (ms): 0
Slave Interface: eth5
MII Status: up
Link Failure Count: 0
Permanent HW addr: 08:00:27:95:e4:45
Slave Interface: eth6
MII Status: up
Permanent HW addr: 08:00:27:48:60:b1
root@PLHQSRDMZ01:~# cat /var/lib/lxc/plhqsrwww01/config
lxc.tty = 4
lxc.pts = 1024
lxc.rootfs = /var/lib/lxc/plhqsrwww01/rootfs
lxc.cgroup.devices.deny = a
# /dev/null and zero
lxc.cgroup.devices.allow = c 1:3 rwm
lxc.cgroup.devices.allow = c 1:5 rwm
# consoles
lxc.cgroup.devices.allow = c 5:1 rwm
lxc.cgroup.devices.allow = c 5:0 rwm
lxc.cgroup.devices.allow = c 4:0 rwm
lxc.cgroup.devices.allow = c 4:1 rwm
# /dev/{,u}random
lxc.cgroup.devices.allow = c 1:9 rwm
lxc.cgroup.devices.allow = c 1:8 rwm
lxc.cgroup.devices.allow = c 136:* rwm
lxc.cgroup.devices.allow = c 5:2 rwm
# rtc
lxc.cgroup.devices.allow = c 254:0 rwm
lxc.utsname = plhqsrwww01
lxc.network.type = veth
lxc.network.flags = up
lxc.network.link = br0
#lxc.network.hwaddr = 00:FF:12:34:56:00
lxc.network.ipv4 = 10.50.12.101/25
# mounts point
lxc.mount.entry=proc /var/lib/lxc/plhqsrwww01/rootfs/proc proc nodev,noexec,nosuid 0 0
lxc.mount.entry=devpts /var/lib/lxc/plhqsrwww01/rootfs/dev/pts devpts defaults 0 0
lxc.mount.entry=sysfs /var/lib/lxc/plhqsrwww01/rootfs/sys sysfs defaults 0 0
root@PLHQSRDMZ01:~# route -n
Kernel IP routing table
Destination Gateway Genmask Flags Metric Ref Use Iface
10.50.12.0 0.0.0.0 255.255.255.0 U 0 0 0 br0
0.0.0.0 10.50.12.1 0.0.0.0 UG 0 0 0 br0
plhqsrwww01:~# ifconfig
eth0 Link encap:Ethernet HWaddr e6:7b:db:5a:dc:95
inet addr:10.50.12.101 Bcast:10.50.12.0 Mask:255.255.255.0
inet6 addr: fe80::e47b:dbff:fe5a:dc95/64 Scope:Link
RX packets:19 errors:0 dropped:0 overruns:0 frame:0
TX packets:6 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:904 (904.0 B) TX bytes:384 (384.0 B)
plhqsrwww01:~# cat /etc/network/interfaces
auto lo
auto eth0
iface eth0 inet static
address 10.50.12.101
gateway 10.50.12.1
plhqsrwww01:~# route -n
10.50.12.0 0.0.0.0 255.255.255.0 U 0 0 0 eth0
0.0.0.0 10.50.12.1 0.0.0.0 UG 0 0 0 eth0
