Strona 1 z 2 12 OstatniOstatni
Pokaż wyniki od 1 do 10 z 17
Temat: brak polskich znakow
  1. #1
    Zaktualizowalem, o ile dobrze pamietam xorg'a, i jak widac wcielo mi polskie znaki. Probowalem w ustawieniach xfce zmienic uklad na polski, ale jest tylko "qwertz". Ma ktos pomysl jak to naprawic?
  2. #2
    A masz w xorg.conf taki wpis:
    Kod:
    Section "InputDevice"
        Identifier     "Keyboard0"
        Driver         "kbd"
            Option          "CoreKeyboard"
            Option          "XkbRules"      "xorg"
            Option          "XkbModel"      "pc105"
            Option          "XkbLayout"     "pl"
    EndSection
  3. #3
    Cytat Napisał gawomontyk
    Poszukać na forum. Jest mnóstwo tematów z rozwiązaniami.
    http://debian.linux.pl/viewtopic.php?p=109250#109250
    http://debian.linux.pl/viewtopic.php...zacja&start=15
    ]http://debian.linux.pl/viewtopic.php?p=80635#80635
  4. #4
    Dodalem to do xorg.conf i aktualnie wyglada on tak:
    Kod:
    Section "ServerLayout"
    	Identifier     "X.org Configured"
    	Screen      0  "Screen0" 0 0
    	InputDevice    "Mouse0" "CorePointer"
    	InputDevice    "Keyboard0" "CoreKeyboard"
    EndSection
    Section "Files"
    	ModulePath   "/usr/lib/xorg/modules"
    	FontPath     "/usr/share/fonts/X11/misc"
    	FontPath     "/usr/share/fonts/X11/cyrillic"
    	FontPath     "/usr/share/fonts/X11/100dpi/:unscaled"
    	FontPath     "/usr/share/fonts/X11/75dpi/:unscaled"
    	FontPath     "/usr/share/fonts/X11/Type1"
    	FontPath     "/usr/share/fonts/X11/100dpi"
    	FontPath     "/usr/share/fonts/X11/75dpi"
    	FontPath     "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType"
    	FontPath     "built-ins"
    EndSection
    Section "Module"
    	Load  "glx"
    	Load  "dri2"
    	Load  "dbe"
    	Load  "dri"
    	Load  "extmod"
    	Load  "record"
    EndSection
        Driver         "kbd"
    EndSection
    	Identifier  "Mouse0"
    	Driver      "mouse"
    	Option	    "Protocol" "auto"
    	Option	    "Device" "/dev/input/mice"
    	Option	    "ZAxisMapping" "4 5 6 7"
    EndSection
    Section "Monitor"
    	#DisplaySize	  330   250	# mm
    	Identifier   "Monitor0"
    	VendorName   "GSM"
    	ModelName    ""
    	HorizSync    30.0 - 98.0
    	VertRefresh  50.0 - 160.0
    	Option	    "DPMS"
    EndSection
    Section "Device"
            ### Available Driver options are:-
            ### Values: [i]: integer, <f>: float, <bool>: "True"/"False",
            ### <string>: "String", <freq>: "<f> Hz/kHz/MHz"
            ### [arg]: arg optional
            #Option     "NoAccel"            	# [<bool>]
            #Option     "SWcursor"           	# [<bool>]
            #Option     "Dac6Bit"            	# [<bool>]
            #Option     "Dac8Bit"            	# [<bool>]
            #Option     "BusType"            	# [<str>]
            #Option     "CPPIOMode"          	# [<bool>]
            #Option     "CPusecTimeout"      	# [i]
            #Option     "AGPMode"            	# [i]
            #Option     "AGPFastWrite"       	# [<bool>]
            #Option     "AGPSize"            	# [i]
            #Option     "GARTSize"           	# [i]
            #Option     "RingSize"           	# [i]
            #Option     "BufferSize"         	# [i]
            #Option     "EnableDepthMoves"   	# [<bool>]
            #Option     "EnablePageFlip"     	# [<bool>]
            #Option     "NoBackBuffer"       	# [<bool>]
            #Option     "DMAForXv"           	# [<bool>]
            #Option     "FBTexPercent"       	# [i]
            #Option     "DepthBits"          	# [i]
            #Option     "PCIAPERSize"        	# [i]
            #Option     "AccelDFS"           	# [<bool>]
            #Option     "IgnoreEDID"         	# [<bool>]
            #Option     "DisplayPriority"    	# [<str>]
            #Option     "PanelSize"          	# [<str>]
            #Option     "ForceMinDotClock"   	# <freq>
            #Option     "ColorTiling"        	# [<bool>]
            #Option     "VideoKey"           	# [i]
            #Option     "RageTheatreCrystal" 	# [i]
            #Option     "RageTheatreTunerPort" 	# [i]
            #Option     "RageTheatreCompositePort" 	# [i]
            #Option     "RageTheatreSVideoPort" 	# [i]
            #Option     "TunerType"          	# [i]
            #Option     "RageTheatreMicrocPath" 	# <str>
            #Option     "RageTheatreMicrocType" 	# <str>
            #Option     "ScalerWidth"        	# [i]
            #Option     "RenderAccel"        	# [<bool>]
            #Option     "SubPixelOrder"      	# [<str>]
            #Option     "ShowCache"          	# [<bool>]
            #Option     "DynamicClocks"      	# [<bool>]
            #Option     "VGAAccess"          	# [<bool>]
            #Option     "ReverseDDC"         	# [<bool>]
            #Option     "LVDSProbePLL"       	# [<bool>]
            #Option     "AccelMethod"        	# <str>
            #Option     "DRI"                	# [<bool>]
            #Option     "ConnectorTable"     	# <str>
            #Option     "DefaultConnectorTable" 	# [<bool>]
            #Option     "DefaultTMDSPLL"     	# [<bool>]
            #Option     "TVDACLoadDetect"    	# [<bool>]
            #Option     "ForceTVOut"         	# [<bool>]
            #Option     "TVStandard"         	# <str>
            #Option     "IgnoreLidStatus"    	# [<bool>]
            #Option     "DefaultTVDACAdj"    	# [<bool>]
            #Option     "Int10"              	# [<bool>]
            #Option     "EXAVSync"           	# [<bool>]
            #Option     "ATOMTVOut"          	# [<bool>]
            #Option     "R4xxATOM"           	# [<bool>]
    	Identifier  "Card0"
    	Driver      "radeon"
    	VendorName  "ATI Technologies Inc"
    	BoardName   "RV280 [Radeon 9200 SE]"
    	BusID       "PCI:2:0:0"
    EndSection
    Section "Screen"
    	Identifier "Screen0"
    	Device     "Card0"
    	Monitor    "Monitor0"
    	SubSection "Display"
    		Viewport   0 0
    		Depth     1
    	EndSubSection
    		Viewport   0 0
    		Depth     4
    	EndSubSection
    		Viewport   0 0
    		Depth     8
    	EndSubSection
    		Viewport   0 0
    		Depth     15
    	EndSubSection
    		Viewport   0 0
    		Depth     16
    	EndSubSection
    		Viewport   0 0
    		Depth     24
    	EndSubSection
    EndSection
    Dodam, ze polskie litery znikly po tym jak zainstalowalem xfswitch-plugin (przelaczanie użytkowników w xfce). Dodatkowo rozdzielczosc mi sie zmienila na bardzo wysoka, niby da sie ja zmienic, ale tylko na czas jednej sesji, gdyz ustawienia nie zostaja zapisane.
    Próbowałem
    Kod:
    dpkg-reconfigure xorg.conf
    i:
    Kod:
    ]X -configure
    ale nic to nie dało. Dodam, ze w konsolach tekstowych, gdy nie sa wlaczone iksy wszystkie polskie znaki sa.
  5. #5
    Przedstaw plik:
    Kod:
    /var/log/Xorg.0.log
  6. #6
    Wywal ten pakiet "xfswitch-plugin" powinno wrócić do normy.
    A "xorg.conf" przywróć do stanu przed instalacją tego "xfswitch-plugin" pakietu.
    Zastosuj "gdmflexiserver" i logujesz się na konto drugiego użytkownika, a przełączasz się między użytkownikami "Ctrl + Alt F7 F8 F9 ..." ile tam będziesz miał użytkowników.
  7. #7
    Wywalilem ten pakiet ale nic sie nie zmienilo. Xorg.0.log (duzo tego, przekracza limit znakow dla tego forum, dlatego na wklejce jest)
  8. #8
    Witaj. Ja miałem podobny problem na Xubuntu. Problem rozwiązałem uruchamiając skrypt znajdujący się w /usr/share/locales, a mianowicie:
    Kod:
    install-language-pack
    Na początku nadaj mu uprawnienia do wykonania, a później jako root:
    Kod:
     ./install-language-pack pl
    Mnie to spolonizowało XFCE. Zresetuj również system po tej operacji. Pozdrawiam
  9. #9
    Cytat Napisał Xorg.0.log
    (WW) AllowEmptyInput is on, devices using drivers 'kbd', 'mouse' or 'vmmouse' will be disabled.
    gawomontyk, przedstaw wynik polecenia:
    Kod:
    dpkg -l | grep xorg
  10. #10
    Kod:
    $ dpkg -l | grep xorg
    ii  xorg                                 1:7.4+4                       X.Org X Window System
    ii  xorg-docs-core                       1:1.4-5                       Core documentation for the X.org X Window System
    ii  xserver-xorg                         1:7.3+18                      the X.Org X server
    ii  xserver-xorg-core                    2:1.6.5-1                     Xorg X server - core server
    ii  xserver-xorg-input-all               1:7.4+4                       the X.Org X server -- input driver metapackage
    ii  xserver-xorg-input-evdev             1:2.2.5-1                     X.Org X server -- evdev input driver
    ii  xserver-xorg-input-synaptics         1.1.2-1                       Synaptics TouchPad driver for X.Org server
    ii  xserver-xorg-input-wacom             0.8.3.2-1                     X.Org X server -- Wacom input driver
    ii  xserver-xorg-video-all               1:7.4+4                       the X.Org X server -- output driver metapackage
    ii  xserver-xorg-video-apm               1:1.2.1-2                     X.Org X server -- APM display driver
    ii  xserver-xorg-video-ark               1:0.7.1-2                     X.Org X server -- ark display driver
    ii  xserver-xorg-video-ati               1:6.12.3-1                    X.Org X server -- ATI display driver wrapper
    ii  xserver-xorg-video-chips             1:1.2.1-3                     X.Org X server -- Chips display driver
    ii  xserver-xorg-video-cirrus            1:1.3.1-1                     X.Org X server -- Cirrus display driver
    ii  xserver-xorg-video-fbdev             1:0.4.0-4                     X.Org X server -- fbdev display driver
    ii  xserver-xorg-video-i128              1:1.3.2-1                     X.Org X server -- i128 display driver
    ii  xserver-xorg-video-i740              1:1.3.0-1                     X.Org X server -- i740 display driver
    ii  xserver-xorg-video-intel             2:2.9.0-1                     X.Org X server -- Intel i8xx, i9xx display driver
    ii  xserver-xorg-video-mach64            6.8.2-1                       X.Org X server -- ATI Mach64 display driver
    ii  xserver-xorg-video-mga               1:1.4.11.dfsg-1               X.Org X server -- MGA display driver
    ii  xserver-xorg-video-neomagic          1:1.2.3-1                     X.Org X server -- Neomagic display driver
    ii  xserver-xorg-video-nv                1:2.1.14-2                    X.Org X server -- NV display driver
    ii  xserver-xorg-video-openchrome        1:0.2.903+svn741-1+b1         X.Org X server -- VIA display driver
    ii  xserver-xorg-video-r128              6.8.1-1                       X.Org X server -- ATI r128 display driver
    ii  xserver-xorg-video-radeon            1:6.12.3-1                    X.Org X server -- ATI Radeon display driver
    ii  xserver-xorg-video-radeonhd          1.2.5-1                       X.Org X server -- AMD/ATI r5xx, r6xx display driver
    ii  xserver-xorg-video-rendition         1:4.2.1-1                     X.Org X server -- Rendition display driver
    ii  xserver-xorg-video-s3                1:0.6.2-1                     X.Org X server -- legacy S3 display driver
    ii  xserver-xorg-video-s3virge           1:1.10.2-2                    X.Org X server -- S3 ViRGE display driver
    ii  xserver-xorg-video-savage            1:2.3.0-1                     X.Org X server -- Savage display driver
    ii  xserver-xorg-video-siliconmotion     1:1.7.2-1                     X.Org X server -- SiliconMotion display driver
    ii  xserver-xorg-video-sis               1:0.10.1-2                    X.Org X server -- SiS display driver
    ii  xserver-xorg-video-sisusb            1:0.9.1-1                     X.Org X server -- SiS USB display driver
    ii  xserver-xorg-video-tdfx              1:1.4.1-1                     X.Org X server -- tdfx display driver
    ii  xserver-xorg-video-trident           1:1.3.1-1                     X.Org X server -- Trident display driver
    ii  xserver-xorg-video-tseng             1:1.2.1-1                     X.Org X server -- Tseng display driver
    ii  xserver-xorg-video-v4l               0.2.0-3                       X.Org X server -- Video 4 Linux display driver
    ii  xserver-xorg-video-vesa              1:2.2.1-1                     X.Org X server -- VESA display driver
    ii  xserver-xorg-video-vmware            1:10.16.7-1                   X.Org X server -- VMware display driver
    ii  xserver-xorg-video-voodoo            1:1.2.2-1                     X.Org X server -- Voodoo display driver
    PS. jmarcin_1984, nie mam żadnego skryptu ,,install-language-pack'' na moim Debianie.
Podobne wątki
  1. [+] Brak polskich znaków
    By Nacrob in forum Software
    Odpowiedzi: 2
    Ostatni post/ autor: 20-12-2009, 13:39
  2. Brak polskich znaków na www
    By Jam_PL in forum Główne tematy
    Odpowiedzi: 6
    Ostatni post/ autor: 26-02-2009, 12:20
  3. [+] brak polskich znaków
    By ArkediuS in forum Główne tematy
    Odpowiedzi: 8
    Ostatni post/ autor: 12-08-2008, 12:02
  4. Brak polskich znakow
    By stephanek in forum Główne tematy
    Odpowiedzi: 2
    Ostatni post/ autor: 25-10-2007, 17:04
  5. [+] Brak polskich znaków
    By stephanek in forum Serwer
    Odpowiedzi: 3
    Ostatni post/ autor: 05-07-2007, 11:53
Uprawnienia
  • Nie możesz zakładać nowych tematów
  • Nie możesz pisać wiadomości
  • Nie możesz dodawać załączników
  • Nie możesz edytować swoich postów
